Network question
COW Forums : Apple OS X
Alan Lacey
Network question
on Oct 27, 2006 at 6:23:09 pm
It is possible to make a direct firewire connection between a single Mac and PC and make a direct peer to peer connection - anyone?
Alan
Bob Woodhead
Re: Network question
on Oct 28, 2006 at 5:50:58 pm
Yup, I use it sometimes. Must be on XP on the PC side. You'll want a bit of shareware called SharePoints as well to make life easier. The protocol on the Mac side is called SMB. I did alot of searching/testing on this a couple of years ago, but forget where I posted the success results. Try searching the Apple forums. You'll need to set a different subnet/IP range for the 1394 ports you're using (than your ethernet). After all is set up correctly, you may need to wait a few minutes for the devices to "discover" each other as well. If I remember anything else helpful, I'll post.
Alan Lacey
on Oct 28, 2006 at 9:23:13 pm
Bob!!
Your a hero. Now I know it's possible I'll bust a gut to get it working.
If you remember any more details please post.
Thank you
Alan
Bob Woodhead
on Oct 29, 2006 at 1:43:58 am
I do remember that it was a real hassle without Sharepoints. Searching Sharepoints & SMB should find you the answers.
Alan Lacey
on Oct 29, 2006 at 7:23:50 am
Done that and thank you very much.
Alan
