Need Help Setting Up Mirrored RAID in OSX!!!
COW Forums : Apple OS X
jordan82
on Sep 22, 2006 at 6:30:24 pm
Dear Creative Cow Members,
I currently own a LaCie Bigger Disk Extreme 2TB external harddrive, which is almost full with data from archived video editing projects. I would like to purchase a second identical drive and set them up as a Mirrored RAID using OSX's Disk Utility. My thinking is that this configuration will provide me with an automatic, real-time backup of my data. I have a few critical questions:
1.) When I set up the Mirrored RAID using Disk Utility, will my existing 2TB of data be erased? If yes, how can I avoid this?
2.) How does the 2TB of data from my existing drive find its way onto the new, additional drive in the Mirrored RAID?
3.) What block size should I use?
4.) Should I use the "Automatic Repair" feature, or is that only applicable if I designate a third, "spare" disc?
Thanks very much in advance for the answers to these questions - I sincerely appreciate your help!
- Jordan
zrb123
Re: Need Help Setting Up Mirrored RAID in OSX!!!
on Sep 23, 2006 at 3:43:59 am
"will my existing 2TB of data be erased"
- Yes your existing data will be erased,
"If yes, how can I avoid this?"
- buy 2 new drives and mirror rade them
"How does the 2TB of data from my existing drive find its way onto the new, additional drive in the Mirrored RAID?"
- You copy it onto the new mirrored raid
