g4 will not boot up
COW Forums : Apple OS X
Mike Hennessey
g4 will not boot up
on Jun 12, 2006 at 5:56:48 pm
HELP!!!!
I have a Duel 1.25 mirror drive G4 running OS X with all of the updates. It froze up and I had to hold the power button down to restart it. Now it won
Simon Carlson-Thies
Re: g4 will not boot up
on Jun 12, 2006 at 9:04:58 pm
Before you panic:
try reseting the PMU... and if that doesn't work try replacing the pram battery, if that doesn't work boot your computer in target disk mode and get your files off onto another computer, and off to the repair shop for you..
Simon Carlson-Thies,
Digital Light Graphics And Animation
Mike Hennessey
on Jun 12, 2006 at 9:18:57 pm
Hi Simon, that was a bit over my head. Can you dumb it down for me?
FYI, I booted off of the system disk, opened disk utilities to verify/repair the disk and they failed. I have an
Curtis Thompson
on Jun 12, 2006 at 9:21:25 pm
hello...
might also want to try disk warrior:
http://www.alsoft.com/DiskWarrior/
there are other technical solutions (fsck being the primary one), however when you can't boot, you would typically boot to the command line and run a few utilities, but if you're not comfortable doing that, then diskwarrior is a valid option in most cases...
sitruc
Simon Carlson-Thies
on Jun 13, 2006 at 12:59:08 am
give the disk warrior a try...
look at this link:
http://docs.info.apple.com/article.html?artnum=300552
to reset PMU
look here:
http://docs.info.apple.com/article.html?artnum=300341
to boot in target disk mode
look here:
http://docs.info.apple.com/article.html?artnum=58583
see if those work then I'll see what I can do to walk you through replacing your pram battery...
Mike Hennessey
on Jun 13, 2006 at 6:13:34 pm
I
Curtis Thompson
on Jun 13, 2006 at 6:32:37 pm
hello...
[Mike Hennessey] "Assuming it does work can I just go on using the computer or do you recommend a clean install?"
well - i guess it depends - probably can't hurt and apple offers a lot of tools to help with that...
sorry to not have a simple answer, but it's sort of a personal decision based on what you find out was wrong...
sitruc
cowcowcowcow
Mike Hennessey
on Jun 13, 2006 at 6:48:12 pm
I'm not sure what I'm going to do. I am at the tail end of a project that I would love to get out the door before I rebuild the computer. I guess I'll check out the apple tools to see how easy it would be and then decide.
Should I still reset the PMU and replace the pram battery?
Thanks a ton for all of the help!!!
FYI, here is what DW had to say:
Curtis Thompson
on Jun 13, 2006 at 6:54:10 pm
hello...
i'd say wait for the end of your project - unix is pretty good and staying fixed when you fix it - windows sorta always likes a reintall after a while, but unix is nicer about that...
if the box is running, there's probably no need to deal with pram stuff - that's sort of a first attempt that might help but if all is well it won't do anything...
sitruc
Mike Hennessey
on Jun 13, 2006 at 7:12:33 pm
Cool. Thanks again for all your help.
