Any Applescript gurus about?
COW Forums : Apple OS X
cowcow
Bob
by
on Jun 5, 2006 at 5:27:29 pm
got a script that needs 1 thing to put it over the top, but can't figger it out:
MacWorld's June Geek Factor article - they lay out a neat Automator/Applescript workflow to set the desktop to a downloaded image, but give no tips on how to modify the script for multiple monitors/desktops. Ideally, I'd like the script to only address one of my two desktops.
here's the section (input is above this segment in Automator):
on run {input, parameters}
tell application "Finder"
select window of desktop
set desktop picture to file "Tiger:Library:Desktop Pictures:Solid Colors:Solid Gray.png"
set desktop picture to file (input as text)
end tell
return input
end run
As it is now, if I disable my 2nd monitor, the script works - otherwise, it fails.
ideas? thanks!!
Simon Carlson-Thies
Re: Any Applescript gurus about?
on Jun 5, 2006 at 9:45:16 pm
Try the recorde function with both monitors enabled...
Simon Carlson-Thies,
Digital Light Graphics And Animation
Bob
by
on Jun 5, 2006 at 11:57:49 pm
I'm sorry Simon, but I don't know Applescript well enough to be able to find an appropriate reference to the "record function". Could you point me in the right direction? Thanks!
Simon Carlson-Thies
on Jun 6, 2006 at 1:04:25 am
Its been a while but there used to be a record function in apple script, but the last time I used it was in OS9 so I am probably not the best person. But if you look on the developer site in their reference library you should be able to find what you are looking for.
