Dual 2ghz G5 some apps not seeing installed Ram?
COW Forums : Apple OS X
RATRAY
on May 11, 2006 at 2:17:19 pm
I have 7GB installed correctly in my machine, the system profiler shows the ram to be present. However the Activity Moniotor app shows only 3GB of hard ram. After effects is also only showing 3GB. I'm running 10.3.9. Could this be the problem? Do I need to upgrade the os? Any suggestions?
Thanks, in advance.
Simon Carlson-Thies
Re: Dual 2ghz G5 some apps not seeing installed Ram?
on May 11, 2006 at 5:06:52 pm
Run Hardware Test
Did you install the memory in matched pairs?
If not try that...
also talk to the manufacturer and see what there replacement policy is...
Simon Carlson-Thies,
Digital Light Graphics And Animation
RATRAY
on May 11, 2006 at 6:16:14 pm
Ram is installed in pairs. System Profiler reads it fine. ???????
Simon Carlson-Thies
on May 11, 2006 at 7:13:30 pm
Well you already stated the problem I didn't notice the OS you were using the first time, 10.3.9 only can use 4GB you need Tiger to use all that ram.
32bit vs 64bit system
Simon Carlson-Thies
Always check system limitations before buying hardware or software...
Deke Kincaid
on May 13, 2006 at 2:54:07 am
Even with Tger though, 32 bit apps can only use around 2.5-3 gig of ram.
