mouse does not work
COW Forums : Apple OS X
jeff
mouse does not work
by
on Apr 25, 2006 at 10:23:28 am
I want to try and reinstall os x on my mac but the mouse is not working. Is there any way around using the mouse, I am stuck at the language dialogue box and can not continue.
Jeff Carpenter
Re: mouse does not work
on Apr 25, 2006 at 4:22:11 pm
Try plugging the mouse into every available USB port on the computer. See if any of them work. After that, see if you can borrow another mouse to try.
This should be working, it sounds like you have either a bad mouse or a bad USB port. If you're lucky, there's just some temporary problem with that one USB port and it will go back to normal after your OS install is finished.
If all of that fails, try using the "Tab" and "Return" keys and see if that's enough to get you through the process. I don't know if it will be, but that's your best bet to try.
