Creating Quicktime Skin
COW Forums : Apple OS X
Colin Williams
on Mar 28, 2006 at 9:03:13 pm
I recently finished all the steps in this tutorial for creating QuickTime Media Skins:
http://www.apple.com/quicktime/tutorials/mediaskins.html
For some reason when I attempt to open the final xml file, it says "QuickTime cannot open the file: "skin_xml.mov"
it is not a file that QuickTime understands (-2048)"
I checked the xml code and rechecked it again and can't seem to open it. Any light on this darkness would be great!
I'm using a G5 dual 2ghz, QuickTime Pro 7.0.3, OSX 10.3.9, Photoshop CS
Colin Williams
http://www.pensivecrow.com
Matt Larson
Re: Creating Quicktime Skin
on Mar 29, 2006 at 11:25:11 pm
I never had much luck with skinning through QuickTime, or with QTVR. Check out LiveStage http://www.totallyhip.com/livestage.asp It's a bit pricey, but it will probably let you do things you never knew you wanted too. They have a free 30-day demo you can play with
Colin Williams
on Apr 3, 2006 at 5:12:17 pm
Thanks. I'll have to check it out. It looks as though you can do some really interesting things with it. I was under the impresson that QT with some xml code was capapble of doing almost the same thing.
Damien Kelly
on Apr 5, 2006 at 8:49:07 am
Hi Colin.
You may need to save the file as plain text.
In TextEdit go to Format>Make Plain Text then save it again.
Change the extention to .mov and you should be good to go.
Damo.
