wallpaper start up
COW Forums : Apple OS X
7_Days
wallpaper start up
on Mar 21, 2006 at 9:35:40 pm
I need to put the company's logo as a wallpaper where you get to use the user of the computer. Example: computer starts up, you see the apple, then loads, and you have an option of which user you want to use... I need the logo there (as a wallpaper) any one knows how to do that? Thank you.
Jose Alfonzo.
Curtis Thompson
Re: wallpaper start up
on Mar 22, 2006 at 2:38:34 am
hello...
i believe that there are a few apps out there that will help you hack this (i.e. there's no os x setting for it) - you could try version tracker for that...
however, the low-budget way to pull it off is to put your desired wallpaper into /Library/Desktop Pictures and rename it to "Aqua Blue.jpg" (i.e. replace the one that's there) - it would eliminate that original wallpaper as an option, but since that's the one used on that login screen, it will make your wallpaper the one that is there...
sitruc
