getting rid of widgets
COW Forums : Apple OS X
paul nevison
on Mar 7, 2006 at 12:10:49 am
hey there
it's very easy to download and install widegets on the dashboard....but how the heck do you delete them?
Jeff Carpenter
Re: getting rid of widgets
on Mar 7, 2006 at 4:02:24 am
If you pick the Widget called "Widgets" you can erase some of them in there. But some you can't. I can't explain why.
SO, the easiest , surefire way to erase them - Spotlight them. Find the file and erase it. Done.
If you really want to be certain, you can look in two places:
(Main Drive)/Library/Widgets
or
(Main Drive)/Users/(Your Name)/Library/Widgets
It will be in one of those two folders.
paul nevison
on Mar 7, 2006 at 11:22:06 am
i must have the widgets that will not die!! im pretty sure you cant delete the apple ones....but even after dragging to the trash from the library and emptying the trash...the little blighters still show up!! bulletproof widgets!!
it would be good if there was some kind of widget manager....i mean what happens when you have 1000 widgets installed? pretty crazy looking dashboard!
G5 DP 2.0
2.0G RAM
OS 10.4.4
QT 7.0.4
FCP 5.0.4
BMD Decklink Extreme 5.4.2
PAL Land
Jeff Carpenter
on Mar 8, 2006 at 11:17:29 am
Do you not have the widget called "Widgets?" It should be the fist one on your list. it lets you turn certain Widgets "off" so even if they're on your system, they don't show up in the tray.
paul nevison
on Mar 8, 2006 at 4:19:01 pm
hey jeff
no i dont have that widget in either of the widget folders on my system....is it avilable to download off the apple site?
G5 DP 2.0
2.0G RAM
OS 10.4.4
QT 7.0.4
FCP 5.0.4
PAL Land
paul nevison
on Mar 8, 2006 at 4:25:34 pm
ok i found the widgets manager by clicking on the plus sign in the lower left hand corner!
G5 DP 2.0
2.0G RAM
OS 10.4.4
QT 7.0.4
FCP 5.0.4
PAL Land
