Spotlight - Spotless - Apple Fix?
COW Forums : Apple OS X
Rory Hinds
on Mar 6, 2006 at 6:41:43 pm
Hi there
Just wondering if anyone know if Apple have address the Spotlight issue of
slowing down your machine and having to use Spotless
to gain back processing power?
Rory
Rory Hinds
http://www.whatismine.com
Jeff Carpenter
Re: Spotlight - Spotless - Apple Fix?
on Mar 6, 2006 at 10:53:26 pm
You can always go in the System Prefrences where the Spotlight options are and set your entire hard drive to the "do not search" setting. This is there so you can omit areas of the HD from the search but I imagine that if you set the ENTIRE hard drive to not be searched, well, you'd avoid any effects that it might otherwise inflict on you.
