Can idvd burn to another external burner???
COW Forums : Apple OS X
mark
by
on Jan 10, 2006 at 6:33:23 pm
Hello,
It doesn't look like I can but I thought i'd ask. I have a Lacie external dvd burner and I was wondering if there was a way to make idvd burn to the lacie instead of the internal burner. I know in toast you can change to which burner you wanted but can you do that in idvd??
thanks
mark
Tony!
Re: Can idvd burn to another external burner???
on Jan 11, 2006 at 3:11:23 am
Officially, no it won't work. You need an internal SuperDrive to burn DVD's from iDVD. However, there is a workaround. You can save your DVD project as a Disk Image (File > Save As Disk Image). You can then burn the image to a DVD with an application like Roxio Toast, or you can even do it with Disk Utility. The exact method varies depend on which version of OS X you are using.
Not hard to do, but you'd probably be better off buying a SuperDrive off Ebay, etc, rather than an external DVD burner, in my opinion.
Tony!
eyecamiam
on Jan 22, 2006 at 1:59:02 am
the new idvd 06 can.
OSX 10.3.8; Quicksilver Dual 1 gig; FCP 3.0.4; Sony camcorder vx2000; write professionally for a variety of media
