HELP: Iomega vs G-Raid Storage Devices
COW Forums : Apple OS X
Eric Gross
on Dec 15, 2005 at 10:38:31 pm
Hey guys I'd like some feedback. I was about to order a firewire hard drive to store projects on. I'm mostly an After Effects/Final Cut guy. I am debating between the 300GB Iomega Black Series Triple Interface and the 320GB G-Raid Firewire 800.
Currently I operate a shiny new Mac Quad and life is good. I do not output direct to tape though that may occur in the future. As always thanks so much.
Tony!
Re: HELP: Iomega vs G-Raid Storage Devices
on Dec 16, 2005 at 10:02:56 am
Hey Eric,
Between those two, G-RAID would be my choice, and its the choice ton's of video editors and graphics pro's. G-SATA would be even better, but you'll need to add a SATA card to go with it. http://www.g-technology.com/Products/G-SATA.cfm
If you want to save a little money, and gain some space, you could go with the OtherWorld Computing (OWC) 500GB Firewire RAID/Drives https://eshop.macsales.com/shop/firewire/1394/USB/EliteAL/RAID/ Maybe not quite as good as G-RAID, but a lot of bang for the buck. They've been making drives for a long time and have been a decent company to deal with.
Also, I would consider Wiebetech's solutions: http://www.wiebetech.com/home.php
Having said all that, right now today, I"d go with the G-tech (raid or single drive. SATA, then FireWire). However, the OWC drives are an excellent cost effective option that I wouldn't hesitate to use for backups, etc. G-Tech is probably overkill for backups unless you're planning on working off of it regularly.
Tony!
P.S. G-Tech has a forum on the Cow, which says something about the company: http://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=176
