Networking problem with PCs
COW Forums : Apple OS X
Ed Stevens
on Dec 9, 2005 at 10:44:31 pm
I have a network setup with 5 PCs and a G5. The G5 can talk to the PCs but I cannot get the PCs to see the G5. What am I doing wrong?
Thanks in advance
Curtis Thompson
Re: Networking problem with PCs
on Dec 9, 2005 at 11:40:33 pm
hello...
check that you have windows sharing enabled in your sharing control panel...
sitruc
Mark Sloan
on Dec 10, 2005 at 2:20:11 am
The other issue is to check what your Workgroup is set to. If it gives you problems just check your Mac's IP address and you can connect that way using Run function from your start menu. Just type \111.222.333.444 whatever the IP address is.
