Sharing a Single Folder
COW Forums : Apple OS X
Dr.Edit A
on Nov 6, 2005 at 5:28:03 pm
I'm on Tiger 10.4.2 with a Linksys Cable Router
I would like to share just one folder with my wife & my kids. My kids are on Windows 2000 & my wife is on Windows XP.
When I turn on Personal File Sharing & Window Sharing & then log on through my kids PC I see everything in my USERS Folder which I don't want.
What steps am I missing, I ONLY want One Folder to be shared.
Thank You
Curtis Thompson
Re: Sharing a Single Folder
on Nov 7, 2005 at 12:30:28 am
hello...
by default, unix (under os x) allows non-owners of a folder to read the contents but not write or execute - in addition, you also get automatically logged into a certain directory (usually your home dir) when you use a username/password combo to connect to a unix box.
if you want to limit a certain account to a certain directory, you can do a few different things - but first, make a new account on the box for them only and give them that username and password - then they'll have a home dir of their own (/Users/[WHATEVER_NAME]. at that point, if you want them to only have access to a another dir on the box, you can:
a. create a shortcut in their home dir to that dir and then they can click on the shortcut
or
b. open the netinfo manager (/Applications/Utilities) and click on users in the middle col - pick their new username and in the bottom panel, change the path from /Users/[WHATEVER_NAME] (where whatever name is the name you gave them) to the path to the desired directory - then when they log in, their home directory is that directory. to find the dir path for any given dir, find it in the finder and do a "get info" on it - the "where" value near the top of that dialog will give you the path...
a is a lot easier and quicker, but you could do b if you really wanted to start them off at a specific dir...
sitruc
