iMovie and MPEG files
COW Forums : Apple OS X
Wayne Carey
on Oct 20, 2005 at 2:30:04 pm
Hey.... Is there a way that I can import mpeg video files (with audio) into iMovie and be able to burn a DVD. Right now, when I import mpeg files and try to burn them to a disc, all I get is the video, no audio. Why is that? As a matter of fact I don't have any audio on my timeline either. How do I convert mpeg files to be able to use them with iMovie.
_______________________________
Wayne Carey
Schazam Productions
Mark Sloan
Re: iMovie and MPEG files
on Oct 20, 2005 at 5:37:58 pm
You have to "demux" the video stream when it is MPEG. Basically, the video and audio are put in one stream... So you can use a "demuxer"...
http://sourceforge.net/projects/macbbdemux
Or, a quick and easy way to get MPEG to DVD is Toast... I record TV using El Gato's Eye TV to MPEG1 files and then use Toast to burn DVDs that play in my DVD player and get 8 to 9 hours of shows per disk (although, at 320x240 resolution).
