Setting hard disk spin-down time on Tiger
COW Forums : Apple OS X
iamfoxman
on Oct 8, 2005 at 10:31:00 pm
I'm having issues w/ my G5 dual 2.7ghz machine running fcp 5 and getting dropped frames error on edit-to-tape function when media is spread over multiple drives...
I think that it is due to the hard drive spinning down that is not in use- then fcp calls for media from that drive & it isn't spinning at speed when it's needed- thus the dropped frames...
HELP!!!
How do I set the hard disks to not spin down or to a longer delay???
Don Greening
Re: Setting hard disk spin-down time on Tiger
on Oct 9, 2005 at 10:08:49 pm
Can you not just go to the energy saver preferences and un-check the box at the bottom of the window that says: "put the hard disk(s) to sleep when possible." ? Or have you done that already? Other than that I used to use a shareware program called "spindown fix" that wouldn't allow any internal or external hard drives to go to sleep. I used it in Panther but I don't know if it's okay to use in Tiger. Google "Spindown Fix" and it should come up.
- Don
