Error message at start up
COW Forums : Apple OS X
Neil Harris
on Sep 20, 2005 at 10:26:37 am
Every time I start up I get an Error Message
Error Could not find login file at start up
Tony!
Re: Error message at start up
on Sep 20, 2005 at 6:55:41 pm
I believe this will help:
Go to your System Preferences > Accounts > Login Items and select anything that says unknown next to it. Then use the "-" sign at the bottom to remove those unknown items (you can try unchecking them instead, if you think you might still need one of them). Most likely you deleted some software and it left something in the login window.
Tony!
