Clock always resets!!
COW Forums : Apple OS X
chris
on Sep 16, 2005 at 9:26:40 pm
Hello,
My clock stopped working. Everytime I startup I get a message that my clock is set before so-and-so date and that this may cause certain applications to run erraticly. I have tried repeatly to reset the clock and then lock it to further changes. But no luck, every startup is the same. I NEED that clock because that how I find things and organize renders and exports and such. Please help!
Thanks, Chris
Jeff Carpenter
Re: Clock always resets!!
on Sep 16, 2005 at 10:38:54 pm
You don't say what kind of Mac you have. Here's the likely solution if it's a Powermac G5:
http://manuals.info.apple.com/en/Battery.pdf
If that's not what you have, take a look at that anyway. That's what you need to do, you'll just need slightly different directions to know where to look. Go to this page:
http://www.apple.com/support/
...find the type of computer you have and search for instructions on that. If you can't find a specific document about it, look in the user manual for your computer. (The manuals are available on that page too.)
chris
on Sep 16, 2005 at 11:13:12 pm
Jeff,
Sorry! I have a G4 Dual 1ghzs. So, I have to replace a battery huh. I'll search for instructions on that.
Thanks, Chris
Harry Pallenberg
on Sep 17, 2005 at 3:46:57 am
Does it say Dec. 31st 1969?
Harry.
Forum Cowmunity Leader: OSX
Forum Cowmunity Leader: Indie & Doc
Dual 1.8 G5 ** 1GB ** 10.4.1
chris
on Sep 18, 2005 at 9:53:33 pm
Yes it does!!! Why?
chris
on Sep 18, 2005 at 9:57:03 pm
It happened after I plugged in a clients firewire drive. Its been running fine since then (4 weeks), I haven't replaced the battery yet.
Chris
Harry Pallenberg
on Sep 19, 2005 at 3:48:20 pm
Ok - let me see if I can find where I stashed my notes on that one... all I remember is that is was not a battery issue. Mine was a G4 dual 800. Are you running Final Cut Pro version 3 or the 1st verion of 4?
I think th enotes are on that computer (which is not at my poffice anymore... but let me look around).
Harry.
chris
on Sep 19, 2005 at 8:24:07 pm
Thanks Harry!
I'm running FinalCutHD or 4.5 and DVDsp4 and all the Adobes. It all works perfectly. Just no clock.
Chris
Tony!
on Sep 19, 2005 at 11:05:12 pm
As far as I remember you have three possible solutions/workarounds (assuming your battery is OK):
Harry Pallenberg
on Sep 20, 2005 at 5:11:41 am
I agree with updating the system software - I think thats what fixed it in the end (along with a total wipe of the drive).
I hope to get to the room where the old machine is and see if any notes are still there.
Harry.
chris
on Sep 20, 2005 at 5:33:01 pm
Thanks Guys! I'll do an update then leave my wireless up.
Chris
chris
on Sep 20, 2005 at 6:17:21 pm
Yea!! It worked. I clicked set date and time automacticaly.
Thanks Guys
Chris
Harry Pallenberg
on Sep 27, 2005 at 11:12:32 pm
Glad it all works... could not find the info I was looking for.
Harry.
