Moving files from WinXP to Mac (sort of a PC problem)
COW Forums : Apple OS X
David Rowan
on Sep 16, 2005 at 5:44:23 am
I'm trying to use a Maxtor firewire drive to move a big pile of files from my PC (winXP) to my Mac.
I hooked the Maxtor one touch to my PC via USB, and the PC says its working fine when I check the device manager, and yet I can't see it or access it anywhere, except for the device manager.
The Maxtor was formatted on a Mac under OS X, could that be the problem?
Any ideas?
DWR
Tony!
Re: Moving files from WinXP to Mac (sort of a PC problem)
on Sep 16, 2005 at 6:14:59 am
Use this to access your Mac formatted drive from with your PC: http://www.mediafour.com/products/macdrive6//
Also, if you're PC and Mac are at the same location, just attach an Ethernet or Firewire cable between them and network them together. It's pretty easy to do.
Tony!
