Networked rendering
COW Forums : Apple OS X
Colin
Networked rendering
on Sep 8, 2005 at 4:38:00 pm
Anybody know any means to utilise the processing power of a number of Macs by networking them together through ethernet or Firewire?
I think one can do this through using an X serve + the software Xgrid - but this is way beyond my budget. Surely there is some simple software utility that one can use to assign rendering tasks to another computer on ones existing network ?
Thansk in advance for any advice offered.
Colin
Tony!
Re: Networked rendering
on Sep 8, 2005 at 7:11:08 pm
The applications need to support network rendering in most cases. After Effects already has a solution for this, as do some 3D applications. You might want to check with your software developer to see if they have a solution for you. It would help to tell us what application/s you'd like to use network rendering with.
Tony!
Colin
on Sep 8, 2005 at 9:18:03 pm
Tony,
I'm using Final Cut Pro + Compressor [ Apple] + Photoshop + PTMac.
Regards,
Colin
