wmv files to quicktime
COW Forums : Apple OS X
mark
by
on Aug 26, 2005 at 12:19:08 am
Hello,
I was wondering if theres a program or convertor out there that will take large wmv files and save them as either an mpeg2 or
a quicktime file. I used flip for mac but it only seems to work with small files. Any suggestions?
thanks
mark
Tony!
Re: wmv files to quicktime
on Aug 26, 2005 at 4:38:16 am
What do you mean by large files? Flip4Mac limits its trial versions to 30 seconds I believe. With the full version you should be able to bring the wmv files into FCP, Compressor, Quicktime, etc and export them to whatever you want unless you are having some sort of conflict or a space/memory issue. You might want to check with the Flip4Mac people incase there is some issue I'm not aware of, but it should work.
Tony!
