Problem with Extended Desktop on Powerbook
COW Forums : Apple OS X
Jonathan L
on Aug 10, 2005 at 4:38:03 pm
I'm having problems using a 17inch crt monitor with my Powerbook. I'd like to use it for an extended desktop but whenever I use that option in System Pref>Displays my crt goes wonky. Using the mirror function works just fine. Is this a resolution issue where the CRT can't keep up with the LCD on the Powerbook and if so can I not somehow adjust the resolution settings separately?
Thanks in advance
Jonathan
