Ephemerally Occluded Parts - How to Mask Them?
COW Forums : RE:Vision Effects
<< PREVIOUS   •   VIEW ALL   •   PRINT
Roland R. Kahlenberg
on Mar 27, 2017 at 12:54:23 pm
As the per title - I have an arm sorta wiping across the upper part of the body and face - see animation
http://www.broadcastgems.com/mediaserver01/Reflex_Q_March27_Ephemerally_Occ...
1) Should I move away entire masks (or a subset of its vertices) away from the animating arm?
I asked earlier about a Render Hierarchy within Reflex but was told that it doesn't exist - me thinks something similar to a Hold Out Track Layer (ala mocha) or a Hold Out Matte thingy will be good. BUTT for now, is there a definitve, best way in dealing with such an issue?
And sorry for a silly Q BUTT where is my installed Documentation - can't seem to find it - sorry been awake for too long.
Cheers!
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Pierre Jasmin
Re: Ephemerally Occluded Parts - How to Mask Them?
on Mar 27, 2017 at 2:25:40 pm
1) For the manual:
http://revisionfx.com/faq/where-is-the-plug-ins-manual-installed/
2) The arm in your example might work better as a separate layer
Pierre
on Mar 27, 2017 at 2:44:52 pm
Ah! Noted!!! Pierre, I've only vaguely looked/read the doc on working with a separate layer - will look into it as soon as I can. From my vague memory, I'll have to roto out the hand in both shots - correct?
I'm still thinking a top-down (mask Timeline hierarchy) hierarchy might be a better/elegant solution.
on Mar 29, 2017 at 3:55:32 pm
Thanks for the link Pierre. I've also managed to create the morph without separating to layers. Simply masking the various facial features and outline did the trick.
Cheers
- Roland
Pierre Jasmin
on Mar 29, 2017 at 9:02:20 pm
Great! - turns out blind techsupport is hard ☺ -- pierre
