Where's the AEP for the Head-turning Tutorial in the Manual
COW Forums : RE:Vision Effects
Roland R. Kahlenberg
on Feb 26, 2017 at 9:57:06 am
Hi folks, I just purchased ReFlex and all is swimmingly good except for a full-body morph I'm doing right now. Hand and body movements are done and look good. But I can't get the head turn to look good - I've created a monster! ☹
A related Q - for a head turn (very similar to the tutorial in the manual, should both the From and To frames match, on each frame, in terms of head action/profile/perspective action? Currently, I've got a few frames where the From frame is ahead of the To frame when the head turns - and I'm wondering if this is the issue.
And regardless of the answer to the Q in the above para, a look at the AEP for the head-turn Moving Morph tutorial would be good too.
Cheers
- Roland Kahlenberg
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Peter Litwinowicz
Re: Where's the AEP for the Head-turning Tutorial in the Manual
on Feb 27, 2017 at 5:48:20 pm
Yeah, you pretty much want things to "more or less" match from frame to frame... and sometimes things need to be separated into different layers if objects cross. Just the nature of morphing.
That said, the RE:Flex morph projects and footage we have available (including head-turn morph) are located here: http://help.revisionfx.com/tutorial/78/ Make sure to read the README file because it points out things "of interest" in the supplied projects.
Pete Litwinowicz
RE:Vision Effects
Pierre Jasmin
on Feb 27, 2017 at 5:52:10 pm
FYI, they are also individually listed under the DOWNLOAD section of http://help.revisionfx.com/album/24/
You have to scroll down to see these
Pierre
on Feb 28, 2017 at 3:32:36 am
Thanks Pete and Pierre. BTW, I had the other links/files but not the one that Pete provided.
Cheers
