Problems with Twixtor... again. :(
COW Forums : RE:Vision Effects
Chloe Green
on Dec 29, 2016 at 11:12:58 pm
Hello, creative cows! thanks to another user, i was able to figure out my previous problem. But it appears I have another problem on my hands. When I do RAM Preview, the pre comp I slowed down is choppy, as if the frames don't go smoothly, if that makes sense. I'm guessing it may have something do with the 'Frame Blending' but I'm not definite. Could someone possibly help? I'm still fairly new to After Effects and Twixtor, so any help would be appreciated!
Pierre Jasmin
Re: Problems with Twixtor... again. :(
on Dec 29, 2016 at 11:21:52 pm
1) In the Preview Panel, check the Frame Rate setting - is it matching your comp settings for FPS? And skip is at 0?
2) In Twixtor Input:Frame Rate slider. Is it matching your source footage frame rate?
Pierre
