frame skip?
COW Forums : RE:Vision Effects
Fabian Charlton
frame skip?
on Dec 19, 2015 at 10:20:06 pm
At a little past 2 seconds why does the video jerk back?
Im used to using GoPro Cine Studios so to slow down all I did was divide 2 to slow the speed down
However now I'm using Adobe Premiere CC, so I put the speed to 20 percent. I usually do that in CineStudios and that never happens.
What am I doing wrong?
Pierre Jasmin
Re: frame skip?
on Dec 20, 2015 at 5:30:27 am
Looks like you are not nesting to make the sequence longer
http://help.revisionfx.com/album/20/
Pierre
Pierre Jasmin
Re: frame skip?
on Dec 21, 2015 at 6:03:10 pm
Also if you are animating by expanding the video track and selecting motion | Twixtor Output: Speed to show up as a curve, try a non linear interpolator (It defaults to linear). You can access the curve types by right-mouse clicking on a keyframe. Make sure the curve does not go backward though which is easy to do if you look at it real small...
Pierre
