DE:Flicker creates artifacts around stars
COW Forums : RE:Vision Effects
Leandro Pérez
on Oct 25, 2015 at 10:57:26 pm
I just noticed that DE:Flicker is creating some weird black artifacts around the stars in my timelapses.
This is without the filter: http://i.imgur.com/ULYPuNH.jpg
This is with the filter enabled: http://i.imgur.com/qHdvwAK.jpg
These are my settings: http://i.imgur.com/jN5gBxo.jpg
I tried everything to fix it, but nothing seems to be working. Any ideas?
Pierre Jasmin
Re: DE:Flicker creates artifacts around stars
on Oct 26, 2015 at 12:21:11 am
Two things to try:
1) Constant Color Fix [ X ]
2) Set Max Color Change to 0% (as this is primarly monochrome)
Pierre
Leandro Pérez
on Oct 26, 2015 at 12:36:44 am
Setting Max Color Change to 0% did not affect very much the results.
Enabling Constant Color Fix fixed the issue, but it also introduced some nasty artifacts as well: http://i.imgur.com/P9gdUMu.jpg
I don't know if it helps, I'm working on a 16 pbc project with the Cineform codec.
Pierre Jasmin
on Oct 26, 2015 at 1:44:48 am
OK
Feel free to hit http://revisionfx.com/support/contact/
Which will send upload video info
If you want tech support as well
Also without Constant Fix on - try Method 2
