new Twixtor broken?
COW Forums : RE:Vision Effects
pierre st-jacques
new Twixtor broken?
on Sep 29, 2015 at 4:44:33 pm
This morning I downloaded the new Twixtor 6.2.2 and after installation nothing seems to work with it. All I get is a still image...
On a Mac Pro running 10.10.5 using Premiere Pro cc2015. Will keep tinkering but I was wondering if anyone else is experiencing this?
Pierre Jasmin
Re: new Twixtor broken?
on Sep 29, 2015 at 6:32:10 pm
Can you confirm if this is Premiere 9.0.2?
Did you apply Pro or Regular version?
Perhaps ping us at tech support @ revisionfx dot com
so we can follow-up
Pierre
pierre st-jacques
on Sep 29, 2015 at 8:16:29 pm
After more tinkering this afternoon I'm realizing that my problem - twixtor not working / only getting a still image - occurs when the speed is set to a negative value, otherwise things seem to work fine.
I'm using the regular version of Twixtor on the latest Premiere Pro - I can't check the number - but I will! - as I'm away from that computer at the moment...
Pierre Jasmin
on Sep 30, 2015 at 12:48:33 am
Yes negative value goes backward, so that only works from a point in clip - as on second frame otherwise you are already out of range
Pierre
Peter Litwinowicz
on Sep 30, 2015 at 12:59:02 am
To add to what Pierre said, from the manual:
Note on negative speed: A Speed% of -100.00 does not simply flip the original sequence so that it plays backwards starting at frame 0. Imagine the play head on your clip. If you are at the beginning of the clip and you tell the machine (Twixtor in this case) to start playing backward, then there's nothing before the clip starting position to play. That's why you will not see a result with a negative speed as the first keyframe. If you play the clip at 100% for a while, then put in a –30% keyframe (or other negative value) at the place where you want to start playing backward you will see proper results.
Pete Litwinowicz
