Motion Blur: 3dsmax - Vray - After Effects - Fusion
COW Forums : RE:Vision Effects
Bernhard Rieder
on Sep 15, 2015 at 7:06:03 pm
Hi there,
searching since hours on google and can't find any specific tutorial that SHOWS clearly the WORKFLOW and use of the ReelSmart Motion Blur Plugin.
Using 3dsmax + Vray:
- How to setup and render the vector files using 32bit .exr
- How to use the plugin within AE
- How to use the plugin within FUSION
Thank you so much for any little help, links, hints, tipps & tricks !
Peter Litwinowicz
Re: Motion Blur: 3dsmax - Vray - After Effects - Fusion
on Sep 15, 2015 at 8:41:07 pm
Have you seen this:
http://www.timsportfolio.co.uk/tutorials/velocity-pass-3ds-max/
Pete Litwinowicz
RE:Vision Effects, inc.
