Reflex morph will not render in AE CC 2014
COW Forums : RE:Vision Effects
Ali Quintana
on Jun 9, 2015 at 8:03:57 pm
I have a great mroph, took me a week to set up.
reders perfect in ramm preview..
now need to render and it just wont render, no error msg nothing, just doesnt do anything when I hit render.
when I try render the whole timeline, the time line renders fine as well, but when it reaches the precomp wth the reflex morph it just stops, again, no message.
Anny suggestions?
Pierre Jasmin
Re: Reflex morph will not render in AE CC 2014
on Jun 9, 2015 at 9:57:52 pm
You need to get the latest update (posted may 15)
Adobe broke it in CC 2014.2
We were able to find a workaround
Pierre
Pierre Jasmin
on Jun 10, 2015 at 12:05:18 am
Also, alternatively save as CC (previous version) and rendering in CC should also work.
Pierre
Ali Quintana
on Jun 10, 2015 at 2:03:10 pm
ok, Im saving ias CC,
but now in what version do I open and render, I only have CC2014
also have cs5
Pierre Jasmin
on Jun 10, 2015 at 2:15:30 pm
If you have CC 2014 it's because you are on subscription, so you can download CC. Run Adobe Creative Cloud app, and in the old version section, select CC. I don't think there is a way to revert back to 2014.1 (AE 13.1).
Or alternatively as I said, update RE:Flex to latest version.
Pierre
Ali Quintana
on Jun 10, 2015 at 1:42:38 am
thx, u mean latest update of AE?
Pierre Jasmin
on Jun 10, 2015 at 1:55:17 am
The last update of CC 2014 - (2014.2) requires the last version of RE:Flex (5.2) otherwise there is some caching issues introduced by AE we were able to workaround hopefully with RE:Flex 5.2.
If someone is still at RE:Flex 4, they will need to either upgrade to RE:Flex V5 or they need to use Save As - Save a Copy as CC (12)... and render in CC (AE 12). If someone has not updated to 2014.2, is still at 2014.1 for example, not sure I would recommend to upgrade AE to latest.
Pierre
Ali Quintana
on Jun 11, 2015 at 4:32:15 am
Is there a way to upgrade without me having to redo the whole keyframing and masking...? It is a huge project.
Or can I buy the latest version and keep my current vrsion also installed? just incase?
Pierre Jasmin
on Jun 11, 2015 at 2:58:13 pm
You should be able to use a different version of RE:Flex without loosing anything in your project.
The plugins are installed here:
CC and CC 2014
Windows: C:/Program Files/Adobe/Common/Plug-ins/7.0/MediaCore
Mac: /Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore
You can always to be sure,
1) Make a copy of your AEP
2) move the RE:Flex folder somewhere outside of the plug-ins folder, install the current version and check.
The only issue is if someone saves from RE:Flex 5 to 4. For example RE:Flex 5 has a GPU menu, that value will not be saved. Similarly saving from CC 2014 as CC 12.0 and loading in CC AE 12.0 should work.
The
