Best Practice For C100 Slow Motion With Twixtor
COW Forums : RE:Vision Effects
joseph wilkins
on Apr 29, 2015 at 4:08:00 pm
I own the original c100 and have a shoot coming up where I need slow motion.
I own the twitter plug in and am wondering if I would get better results shooting 60i - which the c100 can do (not 60P) and use twitter... or should I shoot 24p and slow it down?
Is there a tutorial out there that someone can point me to? I did a search but came up empty.
I'm ultimately just looking for the 60 FPS look.
Thanks in advance.
Pierre Jasmin
Re: Best Practice For C100 Slow Motion With Twixtor
on Apr 29, 2015 at 6:20:47 pm
You should shoot 60i (more samples per second) and the way to handle fields vary per host Twixtor run in, you did not say.
In AE, in Twixtor there is a menu to set fields property. In other hosts it's different, so we need to know the application.
Pierre
joseph wilkins
on Apr 29, 2015 at 6:28:10 pm
Thanks... I am using Premiere... so what settings would I apply to interpret the footage correctly?
