Twixtor on Sony Vegas Pro - interpolation between multiple still images
COW Forums : RE:Vision Effects
Walt Borders
on Mar 4, 2015 at 8:59:35 pm
I've been loading a set of multiple still images into Vegas Pro 13 and then trying to use Twixtor to create a new still image between each source image. The stills are from multiple cameras all pointing at the same scene. Think of a stereo camera but with 10 lens.
My goal is to use still images to create in-between images that will be used to make auto-stereoscopic 3D lenticular prints.
With Twixtor I've been getting plenty(!) of output JPGs, but none that have created an actual interpolated new image. Can I keep working with still images or do I need to create a 10 frame movie and work from that?
Your direction and concepts are much appreciated! Thanks!
Peter Litwinowicz
Re: Twixtor on Sony Vegas Pro - interpolation between multiple still images
on Mar 5, 2015 at 1:02:48 am
You do indeed need to make a 10 frame movie and work from that. (even if that's to tell Vegas to load the 10 frames AS A MOVIE).
Pete
RE:Vision Effects, Inc.
Walt Borders
on Mar 5, 2015 at 3:24:10 pm
Thanks for the info! I was going off in different directions and didn't know what to focus on!
Walt
Pierre Jasmin
on Mar 5, 2015 at 2:01:36 am
A good way to do this in Vegas and to sequence your still frames on the timeline
Then save that as a .veg file (project)
And then load the .veg file as if you were loading a movie, within a new project
And from there, follow Twixtor as usual instructions
Pierre
Walt Borders
on Mar 5, 2015 at 3:25:26 pm
The next step! Thanks for your help!
Walt
