Twixtor breaking collapse transformations?
COW Forums : RE:Vision Effects
Jimmy Brunger
on Nov 11, 2014 at 3:41:07 pm
Hi all,
I have a problem whereby I'm trying to slow down quite a complicated composite...I get too many artefacts when applying to the render/master comp, so I've broken down the shot into instances of the same comp with different layers solo'd - so I can twixtor each one separately without layers crossing over each other and causing the 'jelly wobble'!
Problem is - I have to set collapse transformations for each solo'd comp to retain blend modes, but as soon as I apply Twixtor it forces collapse off?
Is there any way to fix this? I'm using Twixtor Pro 5.2. Rest of my specs are below...
Adobe CC 2014
MacPro 2013 8-core 3GHz / 64GB RAM / Dual FirePro D500s / OSX 10.10
Decklink Extreme+ 3D / 2TB SSD RAID-0 scratch / XServe + UD RAID on Small Tree 10GbE
Pierre Jasmin
Re: Twixtor breaking collapse transformations?
on Nov 11, 2014 at 5:54:41 pm
I am not sure why Twixtor would turn off CT/CR
You say solo, shouldn't you select layer and menu Pre-compose?
Pierre
Jimmy Brunger
on Nov 11, 2014 at 6:18:00 pm
Hi Piere,
Sorry maybe wasn't clear...they have been precomped, but essentially i've got 5 precomps of the same thing, but each one has certain layers within that are visible. It is these layers i need to twixtor individually so no crossing over of objects. I am then stitching them back on top of each other in the parent comp where the instances of twixtor are being applied. I need them CR'd though so it looks through into each one to honour the blend modes.
Thanks for any thoughts you might have.
Adobe CC 2014
Pierre Jasmin
on Nov 11, 2014 at 6:24:18 pm
It might be easier if you have a way to send to techsupport @ revisionfx dot com a project
Pierre
