DE:Noise fails to render errors
COW Forums : RE:Vision Effects
Phil Kurus
on Oct 5, 2014 at 9:41:33 pm
Hey All:
FCP 7, DE:Noise and DE: Noise Frame Average, latest versions. Latest CUDA driver installed. MacBook Pro mid-2012. 1 GB VRAM. OSX 10.9.5
GFX Card Status indicates that FCP is using the GPU as it starts.
New purchaser of DE: Noise.
I keep getting render failures and their error message pop-ups.
Two problems:
1. Individual clips in the timeline (1080i ProRes) will sometimes fail to render, but I can usually skip to a different frame and start over with success. HOWEVER, other, previously rendered clips will suddenly revert to RT orange unrendered status! This means that rendering each clip individually won't work.
2. A full render of the Timeline (Export, QuickTime movie) is impossible. It consistently trips up with a fail to render on one of the DE:Noise plugins, though which instance I don't know.
What am I missing here? Any help greatly appreciated.
Peter Litwinowicz
Re: DE:Noise fails to render errors
on Oct 6, 2014 at 5:22:48 pm
Hello back,
Not sure what's up. You might be running out of memory. (FCP 7 is notorious for this).
How many frames are you trying to accumulate with DE:Noise Frame Accumulate? Also are there any other plugins before DE:Noise (this can cause issues with memory requirements).
Note that DE:Noise does not use the GPU, so there's nothing for DE:Noise to set or unset there.
Perhaps you can send us your FCP 7 project (no media needed just yet)
and I'll take a look. Make sure to tell me what sequence to look at.
send the project to us at techsupport (at) revisionfx (dot) com.
Phil Kurus
on Oct 7, 2014 at 7:17:36 pm
Pete--looks like my partner received your answer via the support link. Thank you.
© 2018 All Rights Reserved
