Twixtor crashing Premiere Pro 2014 on launch
COW Forums : RE:Vision Effects
Joe Bender
on Jul 3, 2014 at 3:50:42 pm
EDIT:
Apologies for the premature post — on further testing it seems to be all my MediaCore plugins that are having problems. I'll keep looking for fixes for that and report back if I find anything.
Hi all —
I'm pretty excited about some of the features in the new PPro 2014, which I decided to try out last week, but it's crashing on launch when it tries to load Twixtor. Plugin incompatibility happens often with new software versions, so I didn't think much of it and figured I'd continue my projects in the old version (not switching horses in mid-stream and all that) and check forums in a week to see if others encountered the same problem. Now I'm not seeing anyone else having this problem. Is there a simple fix that I'm missing?
Thanks in advance for your help!
Joe
Pierre Jasmin
Re: Twixtor crashing Premiere Pro 2014 on launch
on Jul 3, 2014 at 4:00:16 pm
What is the version of Twixtor?
How did you install it?
What OS?
Not clear what you say:
Premiere is crashing on launch with a project with Twixtor in it, on application of Twixtor, just generally crash if installed when Premiere starts?
Pierre
Joe Bender
on Jul 3, 2014 at 4:17:53 pm
Thank you for your response,
Premiere Pro 2014 crashes on launch when loading any MediaCore plugin. I'm going to try uninstall/reinstall once I'm at a place with my projects where I can take the time.
Pierre Jasmin
on Jul 5, 2014 at 12:17:32 am
OK, if it still does it, you should report this to Adobe
Pierre
