Orange Screen/Sequence Settings problem
COW Forums : RE:Vision Effects
Connor Benton
on Sep 24, 2012 at 7:36:27 am
Hi guys, I've been looking through these forums among others and I still am having a problem using Twixtor in Premiere Pro CS6. Using video taken from a ContourHD 1080, shot at 1280x720, H264 - MPEG-4 Codec, 59.940082 frame rate, 1.0 pixel aspect ratio, I am struggling to render Twixtor effects. When rendering in the workspace, I get an orange screen which RE:Vision says is due to the sequence settings not matching the source video. However, I have tried several methods to match the sequence settings to the source video including letting Premiere Pro match it up (the Change sequence settings dialog box), and trying to match it up manually with settings as follows:
Timebase: 59.94 frames/second
1280 x 720 (16:9)
Pixel Aspect Ratio: Square Pixels (1.0)
Fields: No Fields (Progressive Scan)
Display Format: 60fps Drop-Frame Timecode
In both cases, I still get an orange screen when trying to render effects in the workspace. What can I do to fix this problem? Thanks for you help.
Pierre Jasmin
Re: Orange Screen/Sequence Settings problem
on Sep 24, 2012 at 4:34:49 pm
Try right click on clip in project bin and select "New Sequence from Clip"
This can be created with an effect applied before
If it does not work,
This will return you an ftp drop zone to upload a project with example movie
© 2018 All Rights Reserved
