Twixtor Pro vectors in
COW Forums : RE:Vision Effects
Nathan Evans
on Sep 5, 2012 at 5:55:28 pm
I am trying to retime a 3D sequence using my vectors from my render but every time I select my input the screen goes black. ideas?
working in tif 16bit images in a 16 comp in AE CS6
I am trying the demo version before buying to make sure it works first.
Pierre Jasmin
Re: Twixtor Pro vectors in
on Sep 5, 2012 at 6:28:40 pm
It's better you contact techsupport at revisionfx.com
If you hit the support button at the top of our website and then the contact form, it will send you a way to ship to us a project to see.
I am unclear if you mean the whole screen (then memory issue?) or the viewer. If the viewer there might be an issue with the MV themselves. For example if there is no alpha channel in the MV it could throw pixels off the screen... Hard to say blindly.
Pierre
Nathan Evans
on Sep 5, 2012 at 6:48:51 pm
Thanks for the quick response, will send it over.
