higher than 1/2000 shutter speed good for twixtor?
COW Forums : RE:Vision Effects
Zack Mulvaney
on May 11, 2012 at 2:43:25 am
I saw this twixtor tutorial
...and was wondering why 1/1000-1/2000 is the shutter speed range recommended in the tut. Why not go to 1/4000 (which is as high as my T2i goes) or simply 1/2500 or 1/3000. Won't I get better results the higher I go?
Pierre Jasmin
Re: higher than 1/2000 shutter speed good for twixtor?
on May 14, 2012 at 6:28:50 pm
The keypoint is the shorter the exposure the less blur there is in the frame so the easier it is to track, however there is a physical limit to that which is at some point you need to let some light in so the image is not just noise.
Pierre
