Render errors when using a motion vector pass in AE.
COW Forums : RE:Vision Effects
Jordan Montreuil
on Apr 20, 2012 at 9:36:35 pm
I rendered out a motion vector pass with the rest of my passes from Cinema 4D and I am getting some weird errors from RSMB. The blur will just cut off in random areas or there will be seams in the blurs where it should be completely across one object.
I've attached a small screenshot of part of my final comp and of the motion vector in the same spot at the same time.
4015_mberrors.jpg.zip
Pierre Jasmin
Re: Render errors when using a motion vector pass in AE.
on Apr 20, 2012 at 9:41:38 pm
Something wrong
Can you send a project of the app (e.g. AE CS5) with a frame of color/beauty pass and one frame of the MV
(to techsupport at revisionfx dot com)
Also when you do tell us what version of C3D etc
Pierre
Jordan Montreuil
on Apr 20, 2012 at 10:16:46 pm
Hi Pierre,
Thanks for the fast response. I've sent a condensed version of the project.
