Re Map Quality low
COW Forums : RE:Vision Effects
jim cascarina
Re Map Quality low
on Feb 24, 2012 at 10:42:27 am
Hi I'm evaluating Re:Map
and the quality is terrible is this a limitation of the Demo or is there something I should now.
cheers
Jim
senior animator
MGV London
Peter Litwinowicz
Re: Re Map Quality low
on Feb 24, 2012 at 6:43:33 pm
Not sure what you mean by "quality is low." Do you mean it's rather pixelated or coarse?
Two things to check:
1) make sure your UV map(s) are exported as 16 bit or floating point from your 3D system.
2) make sure your project (for example, within AE) is set to 16 bit or floating point.
If you continue to have problems, send us a sample project (AE, Nuke, etc.) and some UV maps and source texture map(s) so we can take a look. You can send that to us at techsupport (at) revisionfx (dot) com.
Pete
jim cascarina
on Feb 27, 2012 at 10:50:28 am
cheers,
my render wasn't 16 bit.
all sorted thanks.
senior animator
MGV London
