Getting out of demo mode
COW Forums : RE:Vision Effects
Bruce Rawlings
on Nov 18, 2011 at 4:11:42 pm
Just bought Twixtor and cannot get out of demo mode. I have entered the key they gave me as instructed but no dice. Cannot contact them as only email support. As usual up against the wire. Any ideas? Iam in CS5 Adobe AE
Peter Litwinowicz
Re: Getting out of demo mode
on Nov 18, 2011 at 6:13:59 pm
Glad we could help you offline and good to see ] you are up and running now.
Pete
RE:Vision Effects, Inc.
andrew Varm
on Feb 27, 2012 at 2:32:45 pm
I'm having the same issue having purchased a pro license, tried deleting all the plugin files I could find and re-installing, but still no joy. :(
Pierre Jasmin
on Feb 27, 2012 at 4:02:15 pm
Are you using FCP?
FCP (and a few other apps) do caching of already rendered frames across sessions, unless you change the value of a parameter you get the frame pre-rendered with an X, the solution is to change a value like put sensitivity to 70.1 instead of 70%
If it's not that, write to us with the product you use and the name under which it was registered (or email address) at techsupport at revisionfx dot com so we can see what is going on.
Pierre
