Motion Vectors out of Maya and vray
COW Forums : RE:Vision Effects
Byron Nash
on Sep 10, 2011 at 12:49:48 am
Can you use the Velocity pass from a Maya vray render with RSMB? We used the 2d Motion Vector pass in mental ray on a previous project but will be rendering in vray on this job. The velocity pass looks different than the Motion Vector Pass.
Byron Nash
3D Artist
http://www.editatjoes.com
Pierre Jasmin
Re: Motion Vectors out of Maya and vray
on Sep 10, 2011 at 2:27:12 am
Yes it looks different -- and you are not alone with that problem
I wrote to them again today, if you have some "5 frames" sequence (rgba and velocity pass) bring it on (use the contact form http://revisionfx.com/support/contact/ to get an ftp download area if needed - and then tell us where it is).
All I know is it is not scaled so there is negative motion in the image so it will work only in 32b but there seems to be a larger problem from my earlier tests.
What is good to trouble shoot is 1 frames static - no motion, and then a simple object like a cube like moving 20 pixels in X per frame and 10 in y per frame or something like that.
Pierre
RE:Vision Effects
