massive render times from Twixtor
COW Forums : RE:Vision Effects
John Reis
on Aug 5, 2011 at 11:00:10 pm
2x 2.8 GHz Quad Core Intel Xeon
12 GB 800 MHz DDR2 FB Dimm
Im a newbie to twixtor
I am in FCP 7, have 1920x1080 Pro Res 422 media.
a 3 second clip at 70% speed takes 1 hour to render? Really?!
Memory is set to 100% in memory cache tab
Peter Litwinowicz
Re: massive render times from Twixtor
on Aug 6, 2011 at 1:19:57 am
I just ran a 3 second 29.97 1920x1080 Pro Res clip at 70% using Twixtor and it took 1 minute 10 seconds on a similar machine.
Please send us a project so we can take a look at how your FCP file is set up. If you could just reduce it to the sequences that are needed and the sequence that uses Twixtor (obviously since you are slowing it down there may be a nested sequence that is needed), or at least tell us which sequence to look at and the part that has Twixtor applied.
You can send the FCP project to techsupport (at) revisionfx (dot) com.
Pete
