Twixtor Problems
COW Forums : RE:Vision Effects
Ben Jones
Twixtor Problems
on Jul 17, 2011 at 4:20:18 am
I have been experiencing some problems lately with twixtor.
When I try and use slomo with twixtor pro 4.5 for bother AAE CS4 amd Sony Vegas 10, my final result is always the same.
When I pre render, the footage will be slomo'd but it will only go for about a second or two, then freeze and go for another second or two and so on.
My aae comp settings are as follows -
1280x720
Square Pixels
FPS - 59.94 (Footage Speed)
ALSO, An example of the problem -
Ben Jones
Re: Twixtor Problems
on Jul 17, 2011 at 6:49:56 am
BUMP
Pierre Jasmin
on Jul 18, 2011 at 3:49:29 am
Did you set the input FPS in Twixtor in AE to 59.94 as well?
