Twixtor in FCP noob question
COW Forums : RE:Vision Effects
Michael Pierre
on May 11, 2011 at 11:14:48 pm
Twixtor / FCP question.
I'd like to slow down a few shots. The footage was shot at 24fps and I'd like it to look like it was shot between 500-1000 FPS.
When I apply the plugin and adjust the "speed" slider in the filters tab (and then render) I always get the wrong portion of the clip.
Are there any very clear step by step video tutorials that outline the process of slowing footage down with Twixtor in FCP ?
thanks in advance!
Pierre Jasmin
Re: Twixtor in FCP noob question
on May 11, 2011 at 11:37:56 pm
You need to make sure there is a 100% speed keyframe at the frame before where you want to start the slowmo (or work in frame mode)
Scoll down http://library.creativecow.net/tutorials/revisionfx
there is a set of for FCP tutorials (in backward order, starts on second page)
Alternatively on our website: http://help.revisionfx.com/album/19/
Pierre
RE:Vision Effects
Peter Litwinowicz
on May 11, 2011 at 11:38:38 pm
Are you trimming the clip where Twixtor is applied? If so you need to watch this tutorial for a workaround that FCP requires (it's a but in FCP not Twixtor!)
http://help.revisionfx.com/album/19/#/tutorial-43
Pete
