Can I shoot NTSC 60p footage, use in Twixtor and output as 25p PAL
COW Forums : RE:Vision Effects
Shaun Grant
on Apr 16, 2011 at 6:31:00 pm
So basically i have a music video coming up where we will be ramping motion a lot, I live in England so we obviously shoot PAL. Now I know that the more frames twixtor has to work with, the better the results.
So with that in mind can I shoot 60p and still output to a 25p PAL format. It is for online release only, so does it even matter which I shoot?
Im using a Cannon 550d/T2i
I usually shoot 50p when using twixtor but I want to get the best results possible!
Thanks for your help
Shaun
Pierre Jasmin
Re: Can I shoot NTSC 60p footage, use in Twixtor and output as 25p PAL
on Apr 16, 2011 at 10:27:37 pm
I am not sure which app you use, but Twixtor in AE allows you to set the In FPS and you set the Out FPS with comp settings. This works except it changes a bit the meaning of your speed curves.
Pierre
RE:Vision Effects
Shaun Grant
on Apr 16, 2011 at 10:36:44 pm
Thanks for your response Pierre but I'm not sure I follow...
So if i automate to music in 60p throughout (using twixtor in all my shots) and render the final comp out at 25p PAL it will throw it all out of whack?
PS I use both FCP and AE (prefer FCP)
Pierre Jasmin
on Apr 17, 2011 at 1:47:35 am
The workflow is different in AE and FCP
In FCP you have to use Cinema Tools to reinterpret the footage so FCP loads all 60 frames in your 25 FPS project, and load the audio separately.
http://help.revisionfx.com/album/19/#/tutorial-47
http://help.revisionfx.com/album/19/#/tutorial-45
In AE there is a concept of FPS within the app and when you change FPS a second of audio remains a second of audio. One option is to simply do the frame rate conversion in a subcomp and then in the main comp animate a speed curve with AE time remappling curve. It will like that also use Twixtor in the subcomp to calculate the in-between frames.
AE
http://help.revisionfx.com/album/18/#/tutorial-36
http://help.revisionfx.com/album/18/#/tutorial-33
