Vray Velocity Pass as vectors for Twixtor Pro Vectors In
COW Forums : RE:Vision Effects
Robert Reimann
on Apr 7, 2011 at 9:00:03 pm
Hi all,
I try to feed Twixtor Pro Vectors In with motion vectors created by Vray Velocity Pass or the standard 3dsmax velocity pass. But unfortunately, I tweak around the max displacement value and the velocity x and y scale parameters, the vectors never fit, the resulting twixtored composition is always looking like transparency blended footage, not fitting together.
Does anyone have an idea?
Best regards and thank you in advance.
Robert
Pierre Jasmin
Re: Vray Velocity Pass as vectors for Twixtor Pro Vectors In
on Apr 7, 2011 at 9:05:43 pm
Just send us a sequence of 3 frames, the color render and the motion vector pass and we will sort it out (techsupport at revisionfx dot com). It's a bit hard otherwise to blindly imagine what could be wrong.
Pierre
RE:Vision Effects
Pierre Jasmin
on Apr 7, 2011 at 9:11:52 pm
and your AE project of course to see you set the input images / project bit depth / colorspace etc correctly
Robert Reimann
on Apr 7, 2011 at 9:31:54 pm
Dear Pierre,
thanks for your immediate reply. I just send you the email with the files for check.
Thanks in advance and best regards
Robert Reimann
