Ping Pong Balls
COW Forums : RE:Vision Effects
Robby Hughes
Ping Pong Balls
on Mar 16, 2011 at 11:40:46 am
Shot footage of ping-pong balls being launched by mousetraps... Long Story. What settings would you use to get a slow motion effect. I'm a complete NOOB when it comes to Twixtor, but I have to get this done relatively quick so I'm freaking out slightly. I have Final Cut Pro and the Adobe CS5 package. ANY input helps! Thanks!
The footage is shot with a 5DmkII at 30fps
Pierre Jasmin
Re: Ping Pong Balls
on Mar 16, 2011 at 8:36:35 pm
The distance of a ping pong ball in motion from a frame to the other might be too large for an automatic process.
We would need to see a short sequence - techsupport at revisionfx dot com
Also I am not clear if you looked at the tutorials Lori did for Twixtor in the Tutorials section here at the cow.
RE:Vision Effects
© 2018 All Rights Reserved
