FieldsKit - 50i to 50p (1080)
COW Forums : RE:Vision Effects
Roland R. Kahlenberg
on Jan 13, 2011 at 6:03:30 am
Hi folks, are there any info I can read up on converting 1080 footage at 50i to 1080 50p.
RoRK
Chris Wright
Re: FieldsKit - 50i to 50p (1080)
on Jan 13, 2011 at 9:02:22 am
some people like to keep it simple and put a 50i(25interlaced) video into an after effects 50 fps comp so that each field becomes a frame. Others like to deinterlace with plugins or hardware boxes then retime with optical plugins.
from fieldskit manual pdf
for fieldskit timing mode:
2x FPS,1 Frame Per Field, place in double framerate comp, interpret fields off in AE.
http://technicolorsoftware.hostzi.com/
