Convert 25P to 50P
COW Forums : RE:Vision Effects
Bo Skelmose
Convert 25P to 50P
on Dec 13, 2010 at 4:27:19 pm
How do I convert 1280x720 25P to 50P using Twixtor? - cannot figure it out - using CS5.
Pierre Jasmin
Re: Convert 25P to 50P
on Dec 13, 2010 at 6:30:56 pm
If what you want is a movie at 50 FPS, rather then a 2X slowmo.
Simply: drop the 25P movie into a comp, change comp rate to 50 FPS, set input frame rate to 25 in Twixtor, and render out the 50 FPS comp at 50 FPS.
Pierre
